What brand/type of boiler is this???
A_little_confused
Member Posts: 1
OK, so I just bought my house. I'm trying to perform the routine maintenance my boiler (oil) and would like to find a manual to it first. Unfortunately I can't figure out what type of boiler it is since its not labeled anywhere on it. I know the burner is a Riello. Can anyone point me in right direction here?
Weil McLain 68
Or it may be a 66,but in either case,it's best days are long behind it! That scorch mark on the burner mounting plate isn't good news. A modern setup will easily knock a third off fuel consumption0 -
I'll say a 68 series too
since the 66 series boilers don't seem to have as many scorch marks as the 68s :-0
The Riello burner is one of the better choices for this boiler, but it's still not very forgiving.
There are much better boilers available now, for both oil and gas. Where are you located?All Steamed Up, Inc.
Consulting0
- 167 Indoor-Air Quality
