furnace
rcbass
Member Posts: 1
i have a air handler with a 2 ton air and a 10 kw heater and the blower kicks on with either one but the air or heat wont work can you advise i have put in a new thermostat with no avail. Ron
Furnace
Do you have a meter to check voltage?0
- 167 Indoor-Air Quality
