Trying this again . . .
28W
Member Posts: 141
in Gas Heating
I'm going to be replacing my thermostat. Is switching off the power to a modcon the same as with an oil boiler? Do I just switch off the power, and then turn it back on when I'm done, or is there a special start-up procedure?
Power.
Yup. Power off. Switch the breaker if you're not sure.0 -
Thanks!
Much appreciated.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
