If our community has helped you, please consider making a contribution to support this website.  Thanks!
Trying this again . . .
                    28W
                    Member Posts: 141
                                  in Gas Heating
                    I'm going to be replacing my thermostat.  Is switching off the power to a modcon the same as with an oil boiler?  Do I just switch off the power, and then turn it back on when I'm done, or is there a special start-up procedure?
            Power.
 Yup. Power off. Switch the breaker if you're not sure.0
            Thanks!
 Much appreciated.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
