Circulator offset from Hydrolink
adkhkr
Member Posts: 6
in Gas Heating
I'm going to be using a Hydrolink...can a circulators iso flange be threaded directly onto the Hydrolink or do you need to have a section of pipe to keep the circulators away from it. I thought I read somewhere that circulators need to be kept away from the manifold a certain distance.
Hydrolink...
In addition to the question above...is the spacing on the Hydrolink ports sufficient for threading on a webstone isolation valve and ball drain valve side by side?0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
