Circulator offset from Hydrolink
adkhkr
Member Posts: 6
in Gas Heating
I'm going to be using a Hydrolink...can a circulators iso flange be threaded directly onto the Hydrolink or do you need to have a section of pipe to keep the circulators away from it. I thought I read somewhere that circulators need to be kept away from the manifold a certain distance.
Hydrolink...
In addition to the question above...is the spacing on the Hydrolink ports sufficient for threading on a webstone isolation valve and ball drain valve side by side?0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 5.7K Gas Heating
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 49 Job Opportunities
