New Pigtail Setup
nz
Member Posts: 125
After installing the 3PSI gauge last year, I figured I could make improvements before this year's heating season. I added a vacuum gauge, and a 30z pressure gauge, in addition to my 0-3PSI gauge. I re-piped it so the -30 to 30 stock gauge is visible (although it never moves.) I also piped in a spot for the vaporstat, which is on its way, and a vacuum release valve.
Looks kind of top-heavy
I'd add some supports, or move some of those gauges or controls to where the original gauge now is.All Steamed Up, Inc.
Consulting0 -
in addition to what steamhead suggests
(which you will need), add a union under the cross fitting so that its easy to take the piping apart each year to wash out the pigtail.gwgillplumbingandheating.com
Thanks
Thanks for the suggestions, I'll get a pigtail and something to stabilize it.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
