New Pigtail Setup
nz
nz Member Posts: 125
After installing the 3PSI gauge last year, I figured I could make improvements before this year's heating season. I added a vacuum gauge, and a 30z pressure gauge, in addition to my 0-3PSI gauge. I re-piped it so the -30 to 30 stock gauge is visible (although it never moves.) I also piped in a spot for the vaporstat, which is on its way, and a vacuum release valve.
    Steamhead Member Posts: 18,502
    Looks kind of top-heavy
    I'd add some supports, or move some of those gauges or controls to where the original gauge now is.
    Consulting
  • gerry gill
    gerry gill Member Posts: 3,084
    edited September 2012
    in addition to what steamhead suggests
    (which you will need), add a union under the cross fitting so that its easy to take the piping apart each year to wash out the pigtail.
    gwgillplumbingandheating.com
  • nz
    Thanks
    Thanks for the suggestions, I'll get a pigtail and something to stabilize it.
