Caleffi auto fill valve question
russiand
Member Posts: 75
I was looking at a caleffi autofill/backflow preventer combo. The pressure can be set with te screwdriver from the top. However there is an adjusting knob on the bottom as well, and I could not figure out what that does. Any info would be appreciated. It shows a plus and minus if I remember correctly. Does it furter refine the pressure or allow to rapid fill or someting?
It's
a shut-off valve.0
- 120 Geothermal
