What kind of pipe?
Volvoguy87
I'm looking at installing a chiller system with heating capability in part of my home. There are no hydronic components in the building, so I get the luxury / curse of installing it all from scratch.
What is the best type of pipe to use for a 2-pipe system that will be used for air conditioning as well as heating (not at the same time, obviously)? Is it possible to buy pre-insulated pipe to make installation easier?
I'm better with steam,
Dave
Dave
dupeRob Brown
I think it would be easier with preinsulated lines...
but sizes for preinsulated pipe are pretty limited. may not be possible to get what you need.
I am generally specifying hard pipe to allow the insulation to be done properly, but maybe a PEX-AL-PEX if you are tooled up with good fittings would be a happy medium.Rob Brown
if they do make them
the price of that pre-insulated PEX is going to shock you.
If given the option, I'd choose Aquatherm pipe. Minimal condensation with chilled water and the insulation work is easy..0
- 62 Biomass
