Insulating steam pipes underground.
Ifollowinstructions
Member Posts: 27
Installing steams lines , seems like the fibreglass insulation under dirt holds moisture and helps to create the pipes to rot. What is the solution?
What if
you coat the pipe insulation with a layer of Childers barrier mastic?gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 120 Geothermal
