underfiring a steam boiler
Adam_13
Member Posts: 49
Hello all! We're looking at an oil to gas conversion in small house with one pipe steam. Th current boiler is firing at an input of 140,000 btuh with a doe output of 115,000. The steam system load is 87,000 (including a missing radiator and the piping pickup) and the boiler has a tankless coil for DHW. We're going to abandon the tankless in favor of a stand alone gas water heater, and so the boiler will only be used for heating. The boiler is about 10 years old. Assuming the boiler to be 80%, the gas conversion burner should only need to fire at 107,000. The near boiler piping is copper and done poorly, so it will need to be repiped. We're wondering
1. Can we fire the boiler at 107, 000, or will it be stuck on "simmer" instead of steam?
2. It's a newer boiler but needs reping and it is oversized. Should we just replace the boiler with an atmospheric gas burner model instead of going with the conversion burner?
We want to keep the steam and are wondering what would be the most cost effective route. Any and all thoughts/comments would be greatly appreciated. Thanks for your time, -Adam
Boiler
What make and model is your boiler?0 -
the boiler is a
Utica SFH3100STLB0 -
Boiler
According to Utica's literature, their 140K and 90K boilers are both 3 sections and have the same water content (10.5 gallons). Dropping inbetween to 107K should be fine.
10 years is sort of the beginning of the "what if" stage. It should, realistically, have another decade of useful life, but may develop those pesky control and mechanical failures in the near future. You can get great benefits from converting the existing boiler to gas. Just be aware that you will spend a decent amount of money to do it. Add to that, the other piping repairs, and you may be close to the price of a new boiler. If it was just the conversion burner, I would lean towards yes. With all repairs...maybe...0 -
But you might be able
to use the conversion burner in another boiler, if the present one dies.
Regardless, the conversion will run more efficiently than an atmospheric- I'd say go for it!
Where are you located?All Steamed Up, Inc.
Consulting0 -
I agree that 10 years
is at that "what if" point, however the conversion burner and repipe would probably be the least expensive route now. Since the boiler can be down fired, and since the bsmt has been finished, we're leaning towards the conversion burner.
Thanks to both JStar and Steamhead for your help and for checking into the boiler info
Are the gas conversion burners noticeably more efficient than atmospheric? I tend to prefer the atmospheric burners because they are silent and usually can be converted to millivolt aftermarket, which works great with steam when there's a power outage.0 -
Conversion burners
If your looking to install a gas conversion burner in a oil boiler good luck! You may as well put a coal fire in there. All the calculations in the world will not save you on this one. You will get heat eventually! Spend the extra few bucks on a new boiler.0 -
Great idea
Great idea! buy another oil boiler and install the gas conversion back in it. Maybe keep a few gallons of oil available..if gas runs out install the oil burner back in.0 -
Disagree
This statement is neither fair nor accurate.
Gas power burners in oil, wet-based, boilers work very well. There's quite a bit of history on this forum to back that up, too.0 -
What would your choice be for a replacement boiler
Since you have reservations about replacing the oil burner with a gas burner, what would be your ideal replacement boiler?--NBC0 -
Really
Smith series 8 with an oil burner or a G-8 with Carlin ez-gas, same exact boiler supplied by the manufacturer either way. That's all I have to say.0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
