Contractor in CT needed
DmitriD
Member Posts: 2
Hi there, I have been trying to find a good steam guy in CT, but it seems like you are all in NYC or MASS...
Can anyone recommend a steam expert in between? I have a Converted Coal Burner running Biodiesel, thinking about switching over to GAS.
the vents were all missing throughout the building, had the burner flame tuned last year and installed a new target wall. The Main vents seem to have been removed, and the building is drafty, still has the single pane double hung windows throughout with leaky sashes, and so forth...it's a huge job, and I spent a fortune last year heating this building, and I am not looking forward to doing that again...
Thanks in advance.
Thanks in advance.
Start by calling
the ones closest to you. If they don't come that far, maybe they will know someone closer.All Steamed Up, Inc.
Consulting0 -
ok
thanks for the suggestion, I will give it a shot...0 -
Request
We would love to see some pictures. Then we can lead you in the right direction, if you can't find a contractor in the immediate area.0 -
Steam guy
Last yr discovered a steam guy in trumbul (fairfield county). Drop me a note if you're still looking and i can pass along contact info0
