Radiator ID Help
Mike2
Mike2 Member Posts: 31
Can anyone help me with EDR for these rads???
    Steamhead Member Posts: 18,502
    edited August 2012
    On the first one
    the closest thing I could find is the Verona, made by American Radiator. It is rated 4 sq. ft EDR at 38 inches tall, 3-1/3 at 32 inches, 2-2/3 at 26 inches and 2 at 20 inches, the same as a standard 2-column rad. The Verona is 8-inches deep, does this match yours?
    For the second one I'd use any single-column chart.
    Any idea who made these beauties?
    Consulting
  • STEVEusaPA
    The first one
    Is extremely dangerous and must be removed immediately....I'll come pick it up for free!
    Of course I'm joking...2 beauties, wish I could help.
  • Mike2
    Radiator ID Help
    Thanks for replies.  Radiator is 34 high, 13 1/2 wide and each section is 5 thick.  My best guess is 10sqft/section.
  • BobC
    BobC Member Posts: 5,566
    Piece of string
    If you can't ID them just use a piece of string to determine the circumference of the tube and multiply that by the total length, that will get you the EDR of that section. It will be accurate for all intents and purposes.
    Bob
    3PSI gauge
