can't read the boiler plate
Duff
Member Posts: 61
OK who's got a little trick to share. Went to look at a boiler tonight and I wasn't able to read the specification plate on the boiler.The boiler is a 6 section converted steam to hot water oil fired. The monster has 1-2" supply tapping and two 1-1/2 return tapping's. The burner is a not a flame retention just a gun type. Can I put something on that plate to bring up the lettering and stamping?
Thanks in advance, Dennis
Sure it's not gravity hot-water?
take some pics and post them here. One of us might recognize it.All Steamed Up, Inc.
Consulting0 -
Pencil tracings?
I've taken a clean piece of paper and placed it over the label, then used a pencil, with light pressure and made a tracing of the plate. May take more than 1 try but does show you whatever impressions are on the plate. Will need to be as clean as it can be before you attempt to recover the impressions.
ME0 -
Useless information
Other than curiosity,what value is the plate info?0 -
thanks for the help
Mark, I'll give that a try, thanks
Mr O'Brien..This house just had an extension put off the side and a full dormer on the second floor. I believe the boiler in place was over sized for the original house. I'm in the middle of doing a heat loss for the entire house for the proper size boiler that will be needed. If the boiler in place can handle the load I may suggest to leave it in place for one more season and just pipe in the additional zones. The plate would help in this situation.0 -
Minor correction...
Pencil RUBBING, not tracing. Google pencil rubbing for mor details.
ME0
- 62 Biomass
