Circulator power factor
James Day_2
Member Posts: 191
Trying to find the power factor of both the grundfos magna and taco veridian circulators. Cannot find anything on the website. Even called both companies with no luck.
Thanks James
Thanks James
lacking direct information
It depends on how the inverter's input circuitry was designed. Could be 0.97 or so if they did it right - otherwise it's just a set of diodes, hopefully with an input reactor.0 -
Veridian
I put together a few power point slides to show some of the benefits when using the Veridian pump. there is a power consumption curve. Let me know if this was helpful.Joe Mattiello
Taco Comfort Solutions0 -
Veridian
