A note from Dan Foley.
DanHolohan
Member, Moderator, Administrator Posts: 16,647
Just got this and am sharing it with Dan's permission:
Hi Dan,
I
just closed a deal on a commercial steam job in DC for $55k. It is a
boiler replacement/system rehab in an old building in Dupont Circle.
They got my name from my Find-A-Contractor ad. They received other bids
but were not comfortable with what they heard. They did some research
and found my F-A-C ad on your website.
On
every steam estimate I go on, I give the potential client a copy of
your book “We Got Steam Heat”. I want them to educate themselves and
understand their system. I don’t get every job but it is a cheap
investment and helps to separate me from the pack.
On
this particular job, we were almost $20k higher than the next closest
bid. The other bidders were not going to do the following:
· Replace the wet return running across the basement that was rotted out, leaking and full of mud.
· Replace the 3” header. The new boiler calls for a 4” header.
· Re-pipe
and replace the main vent. The existing one-pipe system has one #75
main vent for a 450,000 BTU boiler. We are going back with (3) Gorton
#2’s.
· Replace
all the radiator vents. Some are hard to get to but they need to be
replaced. They appear to have last been replaced during the Eisenhower
administration.
· Replace
a leaking radiator that is leaking between two sections. Again, it is
hard to get to but Base-Hit or Leak-Lock (what another contractor told
them) won’t fix it.
· Properly flush, skim, and clean the system. As you say, do it now and get paid or do it later for free. I prefer the former.
Dan,
I know you already know this. Several years ago, I went through my
records and stopped counting when I attributed $1/2 mil. In business
directly to my F-A-C ad. That figure is closer to $1 M by this point,
maybe more. I chuckle when I see posts on the Wall complaining about
business conditions or asking about Service Magic or other BS internet
lead sources that cost thousands of dollars. The answer is right in
front of them and it costs $1 dollar a day! Buy an ad, do good work, do
what you say you will, show up on time, charge more than it costs you.
It’s not that hard.
I
still marvel that I am one of only two contractors in the entire DC
metro area with a F-A-C ad (three if you count Steamhead in Baltimore).
Your friend,
Dan
Dan Foley
Foley Mechanical, Inc.
8390 Terminal Road Unit ILorton, VA 22079
Hi Dan,
I
On
On
· Re-pipe
#2’s.
· Replace
administration.
· Replace
them) won’t fix it.
Dan,
It’s not that hard.
I
Your friend,
Dan
Dan Foley
Retired and loving it.
Thats great news Foley
Very Proud of you. When I did have the business, FAP was the BEST advertising I ever did. It was SOOOOOO reasonable too. Mad Dog0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
