Pensotti WB 3-pass oil boiler
vaporvac
Member Posts: 1,520
in Oil Heating
I posted this on the general ?s page, but it was suggested i may get more answers if I post here...
July 21, 2012
@ 11:31 PM
<a href="http://www.heatinghelp.com/forum/contact/5503204/vaporvac">Contact this user</a>
Pensotti wb 3 pass boiler
My dad in Maine is looking to replace his Burnham boiler with a Pensotti
quadritech series #DK2-4 oil. I haven't found anything referenced on
this website about this brand. I'd like to hear some opinions on this
and perhaps some alternate brand choices. He will be installing this
himself with a bit of help as he did with his prior system. I'm
suggesting a Triangle Tube, but don't know if that is comparable. He's
looking to heat his dhw with it and is looking for direct vent with
high efficiency. The indirect WH is made by Heat-Flo in Ma. The control
is a Honeywell L-4080b aquastat. I can't really get a fix on either.
Any and all help would be appreciated. I want to make sure this is the
best decision for his circumstances. He's using Taco pumps.
Thanks for all the help you've given to me in the past.
Colleen
July 21, 2012
@ 11:31 PM
Colleen
Try this link:
http://www.pensotti-pna.com/Heatline%20Quatech.pdf
Looks similar to most 3-pass boilers- AFUE numbers aren't bad.All Steamed Up, Inc.
Consulting0 -
Happy with my DK2-4
I installed my Pensotti DK2-4 approximately 18 months ago. The only "gripe" I have is the combustion noise. I spoke to the Manufacturer about this and they sent me a different nozzle. I installed it but did not notice any difference. Nevertheless, I would still recommend it.
Kevin
Long Island, NY0
- 116 Geothermal
- 169 Indoor-Air Quality
