DAIKIN A/C
Paul S_3
Member Posts: 1,294
HI EVERYONE MY NAME IS PAUL S.
I WAS AT A NO COOLING CALL YESTERDAY NIGHT IN NYC. IT WAS A DAIKEN A/C SYSTEM, WHICH I HAVE NEVER SEEN.(ONLY HAVE 7 YEARS IN THE FIELD). I HAVE A PARTIALLY READABLE SERVICE MANUAL FOR THE UNIT. ITS A 4 TON SYSTEM WITH 1 A.H. I CALLED DAIKEN AND THEY WILL NOT HELP ME WITHOUT A SERVICE MANUAL IN FRONT OF ME.(PRETTY DUMB , IF U ASK ME....THATS THERE JOB). BASICALLY IVE READ THAT YOU CANNOT RECOVER THE REFRIG..UNLESS ITS IN SOME SORT OF MODE, AS WELL AS EVACUATE AND WEIGH IN REFRIG... CHARGE, AND IVE HEARD THAT THERE IS ANOTHER MODE FOR ADDITIONAL CHARGE????? BASICALLY I AM STUCK . IVE FOUND THE REFRIGERANT LEAK AT THE SUCTION FLARE CONNECTION.FIXED THAT LEAK.CANNOT RECOVER , PROPERLY PRESSURIZED SYSTEM W/ NITROGEN TO 550PSI(AS PER DAIKEN) & WEIGH IN CHARGE. SO, IS THERE ANYONE OUT THERE THAT CAN HELP GET INTO THAT 1ST MODE, THEN GET INTO THE "ADDITIONAL CHARGE" MODE......UNTIL I GET THE SERVICE MANUAL IN THE MAIL.
WOULD BE GREATLY APPRECIATED. THANK YOU
PAUL S<img src="http://www.heatinghelp.com/images/yt.gif?" alt="" />
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
Model Number
Paul,
If you have the model number of the unit, you can get all of Daikin's service manuals on their website www.daikinac.com.There was an error rendering this rich post.
thanxxxx
thank you for the website ....i reall apreciate it ...thanks again
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0
