flushmate explosions
george_42
Member Posts: 121
Has anyone had any problems with the Flusmate system , I read that there is a recall because of explosions
Yep...
http://www.cpsc.gov/cpscpub/prerel/prhtml12/12201.html
I have an apartment complex with a bunch of them installed. Guess I'd better have them check their serial numbers...
METhere was an error rendering this rich post.
I have one of those.
It is one of the recalled ones.
I filled out their form online and they will be sending me a repair kit.
It seems I have the skills to fix it.
One thing they say that I will not do it to turn the unit off until I can rebuild it.
Out of the question! I have only one toilet in the house, and have no anti-laxative pills on hand, and would not use them if I did.0 -
Long distance flush
Flush using the standard 10 foot pole while wearing a protective face mask. The end adapter is item 5b, hand extension for exploding toilets. ;-}0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
