carlin h2l
rwhtg
Member Posts: 34
in Oil Heating
has any body had any experiances with the carlin h2l burner? good, bad, issues? going to a traing class and maybe installing one soon.
Skilled labor isn’t cheap, cheap labor isn’t skilled.
H2L
It is a good burner. Just pay attention in class and ask questions if you are unsure about anything. It is similar to a regular burner in the components. For the most part it is just the control box. You will see. Good luck.0 -
Carlin EZ H2L ?
Hi- What is the status of this burner? i see that it is coming out on some OEM units but is it available yet for retrofitting? Where can I get manual to study? There is a huge residential steam market that is in great need of a staged / modulating oil burner.
- Rod0
