2" radiator valves
Jim Pompetti
Member Posts: 552
Can seem to find them at local suppliers. Any ideas?
2" valves
Jim, they have them at AccentShopping. com, I googled 2" radiator valve and that was the first website that came up.0 -
2 inch Radiator Valve
Jim- Watts and Mepco make a 2 inch radiator valve.
Patriot Supply www.patriot-supply.com carries the Watts 2 inch.. Watts part # RA-1-AP Patriot part # 0067600
For Mepco - see the attached spec sheet- Contact Mepco direct and they can probably help you.
MikeyB's source, AccentShopping.com , carries Legend Valves which are probably quite a bit cheaper than either Watts or Mepco. I bought a couple of Mepco valves and after paying for them, thought they might be made from gold rather than brass though it would be hard to beat the quality.
- Rod0 -
when i cant find something
steam related, i call state supply in minnisota and they either have it or get it. Pretty fast turnaround also. statesupply.comgwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
