2" radiator valves
Jim Pompetti
Jim Pompetti Member Posts: 552
Can seem to find them at local suppliers. Any ideas?
  • MikeyB
    MikeyB Member Posts: 696
    2" valves
    Jim, they have them at AccentShopping. com, I googled 2" radiator valve and that was the first website that came up.
  • Rod
    Rod Posts: 2,067
    edited June 2012
    2 inch Radiator Valve
    Jim-  Watts and Mepco make a 2 inch radiator valve.
    Patriot Supply www.patriot-supply.com   carries the Watts 2 inch..  Watts part # RA-1-AP   Patriot part #  0067600
    For Mepco - see the attached spec sheet- Contact Mepco direct and they can probably help you.
    MikeyB's source, AccentShopping.com ,  carries Legend Valves which are probably quite a bit cheaper than either Watts or Mepco.  I bought a couple of Mepco valves and after paying for them, thought they might be made from gold rather than brass though it would be hard to beat the quality.
    - Rod
  • gerry gill
    gerry gill Member Posts: 3,078
    when i cant find something
    steam related, i call state supply in minnisota and they either have it or get it. Pretty fast turnaround also. statesupply.com
    gwgillplumbingandheating.com
