If our community has helped you, please consider making a contribution to support this website.  Thanks!
RS-44
                    Paul Fredricks_3
                    Member Posts: 1,556
                    Is anyone using this R-22 drop in replacement for A/C? Opinions?
Saw it at the Comstar booth at OESP.
            Another one?
Hi Paul. The only ones I am aware of now is R 406&407C Ref, Which only 1 is a drop in. I'd be interested to see additional choices..
Mike T.0 -
            info
It looks like RS-44 is a great alternative. Same cooling capacity at lower pressures equals lower energy costs. Here's some info I found online:
http://www.achrnews.com/articles/finding-alternatives-to-r-22
http://www.rscool.com/RS-44.html
I don't see a down side. Wondering if anyone is using this product.0 -
            Forane R-427A
We have recently done two replacements using Forane's R-427A. Temperature Glide is almost identical. Pressures are identical to 22. We decided to change the compressor oil to be safe. Took out Mineral Oil, went back with POE because I was concerned about oil return. Will check the oil in a month to look for carry over.
I am paying special attention to these two to see how it works. I will keep you posted.
I wish someone would just pick something and lets stick with it. I don't care what it is, just pick something. In a couple of years we are all going to be carrying around 10 different refrigerants to cover all the drop in replacements that we all tried.
Just my $.02.0
 - 87.2K THE MAIN WALL
 - 118 Chimneys & Flues
 - 113 Geothermal
 - 164 Indoor-Air Quality
 - 73 Pipe Deterioration
 - 6.4K Radiant Heating
 - 393 Solar
 - 15.5K Strictly Steam
