What size is this 20 Mills Boiler?
heaterman
Member Posts: 2
I need to know the heating capacity of a 20 Mills Steamer. The jackeyt is 39" long, 45' tall and 29" across. Thanks
Boiler Size:
Lift off the top cover and count the sections. That will tell you what the output is. Either look on the rating plate that should be there or go to the Smith Web Site. The info is there. Or someone else may tell you what you want to know.0 -
Smith Boiler:
Because no one answered trhis,
You need to take the top covers off and count the sections as I said before. The height of the boiler can be meaningless because it either has a chamber and a base in which the boiler block assembly sits that makes it higher or it is a "low Set that sits on a 4" base.
You have to count the sections. The easiest way.
IMO.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
