help with load calculation results
FrankR
Member Posts: 3
in Oil Heating
Can anyone tell me how to size a new boiler for my house. I've had several radiation studies done with wildly different results. One study was done by counting all radiators (size number of tubes and sections) in the house and measuring the rooms and another one was done by mesuring rooms, doors and windows. I have a hot water oil fired boiler and I am more confused now then ever
Heat Load
Hot water system boilers are first sized by measuring the envelope of the building ... measuring door walls and windows ... This would give you the BTU needed on the coldest day .
If radiators in home are larger then what is needed then lower water temperatures can be used to heat the home .
Measuring radiators are used for steam systems , to produce enough steam to fill the whole system ..
If boiler also produces the homes domestic hot water .. You may need to adjust size for it ... Depends on your want and needs ...
Hope this helpsThere was an error rendering this rich post.
Thanks
Big Ed
Thanks for the explaination, I'm a little less confused now0 -
A corollary
Sizing a hot water boiler by measuring radiators alone is WRONG.0
- 167 Indoor-Air Quality
