E. S. P. where can I find in the airhandler
laP
Member Posts: 1
I have installed the central system and I'm about to design duct for my house, In order to get the right E S P i need the blower performance data, cant find in the airhandler, I have called the suport for help few times, no help. I have 3 ton carrier airhandler, model FV4c any help would do. thanks
Data
Call Pearce Phelps. They are a distributor in Camp Hill PA. Their tech help is above and beyond good. If they don't have the data to send you they will tell you where to get it.
Just curiosity. Why a ducted system. The Fujitsu mini splits are leaps and bounds higher in efficiency and keep a home at a better constant temp. Plus with the way the system works each head is its own zone.0
- 123 Chimneys & Flues
