oil fired hot water run with out water
Rock
Member Posts: 50
in Oil Heating
I let someone in my house do my hardwood floors and with out telling me he fired up my oil fired hot water boiler with the wate feed turned off. I had turned it off because the relief valve was leaking and the house was vacant. After replacing the valve and firing it back up I noticed a large puddle by the burner. I moped it up and turned up the thermostat to see if the system was working correctly, which it was except for the leak. . The leak seamed to be gone. Then I noticed it was wet only under the boiler it self. Could it have cracked due to no water?
Yes
have a professional check it to be sure. Where are you located?All Steamed Up, Inc.
Consulting0 -
Locatiion
Patchogue on LongIsland NY0 -
maybe
but I would be leaning more towards a coil or circulator flange gasket leak0 -
I agree with Bill
If you just turned off feed and didn't drain system,it's not dry!0 -
Which is why
you need a pro to look at it and see just where the leak is. Bob, Patchogue is in your area, correct?All Steamed Up, Inc.
Consulting0 -
Did you look
underneath the burner before firing the burner. Some older boilers tend to leak a little if the boiler water gets around room temperature.0 -
Conclusion
I shut this burner off a couple of weeks ago since the house was empty, after shutting it down I noticed water leaking out of the relief valve. I turned off the water feed and drained the water from the relief valve . then plugged the relief valve. Then the floor guy came in and turned the heater on and opened the feed valve.To make a long story short, I replaced the relief valve and fired the system back on. At first no leaks. About an hour later went down in the basement and found water on the floor. Moped it up and a week later with the boiler on no leaks. So it looks like it has something to do with shutting the burner down and restarting it.0 -
YIKES
PLEASE UNDER ANY CIRCUMSTANCE, DO NOT PLUG THE PRESSURE RELIEF VALVE. EVER!!!
As the others have said, you need to get a pro in there, there are a few on this site near your area.
Also, you need to keep the flooring guy to stop touching your system.There was an error rendering this rich post.
AGREED!
You were EXTREMELY lucky something did not explode. Plugging the relief valve is dangerous. Shut that boiler down NOW and have a REAL PRO fix it!
There are several good contractors on Long Island. One of them is in this thread- Bob O'Brien. His company is Technical Heating, 631-473-1597.All Steamed Up, Inc.
Consulting0
- 116 Geothermal
- 169 Indoor-Air Quality
