piping indoor wood boiler and gas boiler
youper
youper Member Posts: 1
Looking to hook indoor wood boiler with gas boiler with indirect h2o heater without doing primary secondary piping on a one pipe loop with 4 loops could anyone show how the piping would look and would it mater any if pumps were on return or supply
  • Steve Whitbeck
    Steve Whitbeck Member Posts: 669
    wood stove tie in
    Just install two tees in the return line to gas boiler above the pump and run the upstream tee to the inlet of the wood boiler and the other tee ( closest to the gas boiler pump ) to the wood boiler output line. If this is not a pressurized wood stove than you will need to install a heat exchanger between the gas boiler and the wood stove.
  • SWEI
    SWEI Member Posts: 7,342
    You're in luck
    idronics 10 just hit the streets with a focus on wood-fired hydronics
    http://www.caleffi.us/en_US/caleffi/Details/Magazines/pdf/idronics_10_us.pdf
