Bray oil fume
memnosine
Member Posts: 7
Hi:
I have an older solar space heat system using Bray oil as the working fluid. (An antifreeze/anti-corrosion water mixture is the storage medium.) I have a leak somewhere and have noticed a slight "hot engine" odor lately (several months now). Is this the Bray oil or the tank fluid? What is it's health effect? How much should I be worried? Thanks for considering this.
Possible leak in old system
I am not familiar with the specifics of "Bray Oil", but if your odor smells like an overheated car, I would guess that it contains ethylene glycol and some corrosion inhibitors. Ethylene glycol is toxic to humans if ingested or inhaled as a aerosol (spray mist). It is very toxic to cats and dogs. My thoughts are that the corrosion inhibitors have failed, and that a metal fitting somewhere may be leaking, or a pipe or tube may have failed. I suggest you find the leak, or get a pro in to find it ,and repair it immediately. Solar systems need routine maintenance, and some of the older systems may have reaching the end of their usefulness.0 -
Bray oil fume
I'm not up on Bray oil either, but I do know it's a high temp hydralic fluid -developed for the space shuttle- and I can't identify any particular odor. I've also gazed at the heat transfer tank and smelled nothing, nor have I seen any sheen on it's contents. The heat storage tank is 400 gallons of water with a "corrosion inhibitor" added. The tank is filled with clear green liquid, open to he basement through a pressure release stand pipe.0 -
Odor issue with solar heating
I was going to advise you to post your questions on the "Solar" thread on this website, and I see that you already have. Possibly you are smelling the fluid you describe as "clear green" like most automotive anti-freeze is, from the atmospheric vent in the basement. There is no sniffer that would detect ethylene glycol, but any lab could tell you what's in that fluid.0
- 15.8K Strictly Steam
