Webstone check flanges
SWEI
Member Posts: 7,356
I have to thank Webstone for their ball drain (and all its relatives) -- have yet to encounter a job where they aren't useful.
I'm wondering about the check flanges - anyone have field experience with them? Looks somewhat better built than a typical pump-integrated flow check and would sure simplify some of our Aquatherm transition piping.
--thanks
--thanks
I've used them...
For about 3 years now, even on my own system. No problems yet.There was an error rendering this rich post.
thanks
Will be installing three of them next week.
Surprisingly low Cv (had to call them to find out how low.) At least they have replaceable innards, and you can get to them from the flange side.0 -
surprising to me.....
I just received their full catalog last week...and nowhere was Cv mentioned...So maybe they'll put out a bulletin, or have one handy when people ask.
Good luck...There was an error rendering this rich post.
Not in the catalog
Only on the spec sheets -- which are not well advertised on their website. Look in the right-hand column of the site under 'Product Knowledge Resources' and click on 'Technical Resources' and then choose by series number - no names given, so you'll need to refer to the catalog to figure out which spec sheet to download.
How about a link to the spec sheet from the product page, guys?0 -
good advice....
Thanks.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
