firing stages
lebou
lebou Member Posts: 1
Can an 4-stage Laars Pennant boiler be programmed to fire in
2-stages by giving the stages 1 and 2 the same setpoint and giving stages 3 and
4 the same set point?
  • Steve Whitbeck
    Steve Whitbeck Member Posts: 669
    Why
    Why would you want to do that - more stages means more efficiecy.
  • furnacefigher15
    furnacefigher15 Member Posts: 514
    Yes I Believe so
    But you may want 1 and 3 together and 2 and 4 together.
    That will help even out the heat transfer.
