Has anyone ever seen one of these?
BRIANJ
BRIANJ Member Posts: 118
Saw this on ebay. Looked like a nice tester. Sorry I didn't post it while it was still active.
<a href="http://www.ebay.com/itm/130648871515?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649">http://www.ebay.com/itm/130648871515?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649</a>
brian
    Steamhead Member Posts: 18,194
    That old beauty
    is now at our shop!
    Consulting
  • gerry gill
    gerry gill Member Posts: 3,083
    I'm hugely
    JEALOUS!!!
    gwgillplumbingandheating.com
  • BRIANJ
    I guess you did see it
    Congratulations Steamhead.
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Jealous Too!
    I did not see this item!  If I had, I would have been bidding.  I would have paid more than $25!   You gotta good deal, Steamhead!
    Dave in Quad Cities, America
    http://grandviewdavenport.com
    Credit Gordo
    he saw it before I did.
    I'll get him to take some pics of what was in there. It appears to be a salesman's demo unit for Hoffman's #2 vacuum vent. Lucky it missed the World War 2 scrap metal drives.
    Consulting
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    Cool!
    What does it do?
    As far as I can tell
    You fill it with water, screw a vent into it and light off a can of Sterno underneath. The vent closes on temperature, then you take it off the flame and watch it form a vacuum.
    I believe it has some sort of safety valve. Also there is a cock so you can release the vacuum, and a glass opening to see the water level.
    Consulting
  • Hap_Hazzard
    A conversation piece.
    I don't suppose you can put a teabag in there. :-)
  • Hap_Hazzard
    edited March 2012
    Another collector's item
    I happened to come across this today and thought is was cute. Might make a nice paperweight. If you still use paper. :-)
    http://www.ebay.com/itm/STEAM-RADIATOR-from-REUTTER-PORCELAIN-miniature-/150706728613?pt=LH_DefaultDomain_0&hash=item2316d22ea5#ht_500wt_1180
