Has anyone ever seen one of these?
BRIANJ
Member Posts: 118
Saw this on ebay. Looked like a nice tester. Sorry I didn't post it while it was still active.
<a href="http://www.ebay.com/itm/130648871515?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649">http://www.ebay.com/itm/130648871515?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649</a>
brian
brian
That old beauty
is now at our shop!All Steamed Up, Inc.
Consulting0 -
I'm hugely
JEALOUS!!!gwgillplumbingandheating.com
I guess you did see it
Congratulations Steamhead.0 -
Jealous Too!
I did not see this item! If I had, I would have been bidding. I would have paid more than $25! You gotta good deal, Steamhead!Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Credit Gordo
he saw it before I did.
I'll get him to take some pics of what was in there. It appears to be a salesman's demo unit for Hoffman's #2 vacuum vent. Lucky it missed the World War 2 scrap metal drives.All Steamed Up, Inc.
Consulting0 -
Cool!
What does it do?Just another DIYer | King of Prussia, PA
As far as I can tell
You fill it with water, screw a vent into it and light off a can of Sterno underneath. The vent closes on temperature, then you take it off the flame and watch it form a vacuum.
I believe it has some sort of safety valve. Also there is a cock so you can release the vacuum, and a glass opening to see the water level.All Steamed Up, Inc.
Consulting0 -
A conversation piece.
I don't suppose you can put a teabag in there. :-)Just another DIYer | King of Prussia, PA
Another collector's item
I happened to come across this today and thought is was cute. Might make a nice paperweight. If you still use paper. :-)
http://www.ebay.com/itm/STEAM-RADIATOR-from-REUTTER-PORCELAIN-miniature-/150706728613?pt=LH_DefaultDomain_0&hash=item2316d22ea5#ht_500wt_1180Just another DIYer | King of Prussia, PA
