Eternal hybrid water heater
TonyS
Member Posts: 849
Any experience with this unit? good bad or indifferent.
Local supplier is going to start handling them and is going to do a demo for local masters association.
They appear to be a nice unit but Im a little wary about how you can use the existing 1/2 inch fuel line. You can never get more out than you can get in. This kind of rhetoric always turns me off.
The 1/2" line....
is only on the smallest unit that they just introduced. I just put one in it was ok. it does out out some hot water. Not easy to set up w/ a comb tool.... not sure if I will do one again. Not a cheap unit. It eliminates the cold sandwich...0
