commercial indirect water heater
bob eck
Member Posts: 930
looking for a commercial indirect water heater 120 gallon ASME rated unit.
Turbomax makes one....
http://www.thermo2000.com/content/en-US/s2_produits/optimizer.aspx
Bear in mind that this is a REVERSE indirect, and it will cause a non condensing boiler to condense under the right conditions. Obviously not a problem with a condensing boiler ,but definitely needs to be taken into consideration for non condensing appliances.
And they do make an ASME model.
ME0 -
So does Viessmann....
http://www.viessmann.us/en/products/speicher-wassererwaermer/Vitocell-V_300.html0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 386 Solar
