circulator sizing for wood boiler
Marc K.
Member Posts: 15
I have a customer who purchased an indoor ewood boiler (Wood Master Flex Fuel, looks very well made), that comes with a buffer tank. I suggested a hx on the system side, on the outlet of the buffer tank. Manufacturer says not necessary. I need help with sizing a circulator for what is, essentially, an open system. I know my load, to calculate gpm, but not sure how to go about calculating head. Would appreciate any help.
(Manufacturer has specified circ. between boiler and buffer tank, a taco 2400-20B)
The brochure for that boiler shows an expansion tank in the diagram...are you sure it is an open system?
That seems like a lot of circulator just to pump water through a solid fuel boiler and a storage tank, but maybe there is something I'm missing inside the boiler. When in doubt, follow the directions....or call the manufacturer and see what their reasoning is.0
