Laing(?) electric boiler pump combination?
solradman
Member Posts: 58
Does anyone know if the Laing(?) electric boiler/pump combination is still available and where to get it?
You Might Try
Check out www.laingpump.co.jp/download/heatings-english.pdf
There is contact information at the bottom of the above file. Don't know if that could get you where you need to be.
Good Luck! Jerry0
