Behind those walls
Gordy
Member Posts: 9,546
Upon doing my shower recon one wall is exterior. Now I have insulation details answered that were sketchy. Anyone ever here of Balsam Wool insulation. Well I got it in my walls.
May be helpful when making wall insulation assumptions in heatloss calcs.
Basically it is fire treated wood products wrapped both sides, and edges in asphalt impregnated kraft paper about 5# felt consistency. Actually it was installed quite nicely. The perimeter of the batts are nailed every 4" sides top, and bottom. Man they used a lot of nails back then
Problem with the batt design it resembles a pillow so edges are thinner, and poofy in the middle. So at best the batt is an r-5 in the middle 2" thick, but its perimeter in the stud bay is about as air tight as you could get in the 50's. You dont get the convection loop inside the batt like a fiberglass batt does..
<img src="http://inspectapedia.com/sickhouse/asbestos/BalsamWoolInsul011DJFss.jpg" width="320" height="240" alt="photo of balsam wool building insulation" />
Gordy
Gordy
Thats a new one for me.....
Just make sure there's no asbestos in there. Sounds like a poor insulator. If you got it exposed, youre probably better off yanking it and redoing it with regular batts, and continuous vapor barrier for the bathroom.There was an error rendering this rich post.
Wood product
Hence the name balsam wool. No asbestos. Still fire proof except the vapor barrier poof.0 -
Those are....
pretty popular around here (NH) in house that age. It was better than nothing. I supose the fireproof thing was to help if ballon framing was involved. FWIW, I would remove it and fill the cavity w/ polyiso board and some spray foam... @ 3.5" that will give you an R-24.5.0 -
I agree with Kevin...
NOW is an opportune time to yank the low R value insulation, and replace it with some super duper R valued foam.
Bear in mind the need for avoiding/eliminating vapor.
ME0 -
Use
urethane foam, especially in a shower wall. It's closed-cell and will not absorb water. It's pricey, but for a small area,it's well worth it.If you have any doubts about its insulation value, pour boiling water in a 1/8" thick styro-foam cup.It's barely warm on the outside.0 -
Just do not put any lemon juice in there with the boiling water. The cups dissolve pretty quickly (tens of minutes, not seconds). At least if there is a tea bag in there too. I suspect polyurethane foam would resist lemon juice or other weak acids better. Carbon dioxide dissolved in water is a weak acid. I never tried dissolving cups with it though.0 -
I
had an installer get kinda indignant with me for that mistake....It's urethane, not polyurethane......Like I should know the difference,or care, for that matter.0 -
Replace insulation
Yeah deffinetly Just wish it was more than 3 stud bays. Should also note that the copper tubing in the pic is the return for the ceiling radiant loop. One must be surgical about demolishion at times.
Gordy0 -
urethane
Is a monomer - not much use in the real world. Polymers (long chains of linked monomers) are.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
