9 units
jrbayside
Member Posts: 81
I have 1 riser that doesnt get hot, it leaves the bioler hot runs about 90 feet before it goes vertical. Its hot until about 5 feet from the vertical pipe. Would a main vent help the problem?
cold riser
what was the result of the tests we suggested you run with the radiator vents?
main vents are definitely needed.--nbc0
- 109 Chimneys & Flues
- 975 Plumbing
- 387 Solar
- 17 Recall Announcements
