Expansion Tank Pipe Size
152NP
Member Posts: 49
Can anyone tell me how to correctly size the piping connecting an expansion tank to the system? I am currently installing a 40gal tank on a 130,000 Btu system. Water temp in the boiler loop where the tank will connect will be 190, and the tank will be charged to 19psi.. The tank comes with a 1 1/4 inlet, which got me wondering. I figured I better check with those than know more than be before bushing this down to 1/2 in to connect to a spirotherm. The tank is large to accommodate a three story building with cast iron radiators, and to work with a solid fuel boiler without using a dump zone.
1/2" should be fine...
The velocity of the expanding fluid will be nil.
The diaphragm is made for he temperatures and pressure it will be seeing, so no benefit to running a larger pipe to dissipate heat before it sees the bladder.
ME0 -
Thanks for the info. That is what I thought, but sometimes what seems to make sense to me turns out to be wrong for some unforeseen reason. I figured it was best to check with someone when potential safety is involved.0
- 167 Indoor-Air Quality
