Save this pipe overhaul -- in progress!!
roskoe
Member Posts: 1
in Gas Heating
So far
So far so good. On most of the boilers that have to be piped primary secondary the pump needs to be on the return. He actually read the instructions instead of using them as a knee pad! Those two tees should be the feed and return for the indirect.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
