honeywell actuator
chuck172
Member Posts: 90
Does anyone know if I can use a Tekmar Mixing Setpoint Control 153 to control a honeywell M6063 Actuator and V5442 Compact Rotary 4 way Valve?
I don't see why
I don't see why you can't. Any reason why you don't want to use the recommended AQ-675? Should be compatible with any PID control, like Tekmar. I would call Honeywell just to double check.There was an error rendering this rich post.
