Do you know what this steam contol is?
[Deleted User]
We ran across this vacuum controller at a school it is tied into the steam regulator.Does anyone know what is is or how it work?
What control?
No picture.................................. But I'll guess its a vapor stat0 -
Is the regulator
placed on the steam main at the boiler?
If so, that control adjusts the regulator to maintain a specified vacuum. With this setup, there is vacuum in the steam mains as well as the returns. This might be a Dunham Vari-Vac or similar system.All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
