monoflow question
jonny88
Member Posts: 1,139
hi,i would value some input into a ? i have on a heat job.i am redoing my basement.i have 4 sunrads to pipe in.would i be better to run a monoflow system or pipe the zone into a manifold and feed the radiators individually from the manifold,thanks for any advice.
mono flow
Mono flow systems don't like to push HOT water down unless you have a good sized pump on the supply side. IF these rads are going to be in the basement. You could mount these horizontal at the ceiling.0 -
monoflow question
thanks steve,i read in dans book pumping away that if using a monoflow system and the rads are below the piping you should use two monoflow tees.i just like the idea of the manifold as i can feed each rad individually and running the pex will be better as there is not much space.0
- 85.8K THE MAIN WALL
- 50 Biomass
- 419 Carbon Monoxide Awareness
- 75 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 857 Plumbing
- 5.8K Radiant Heating
- 373 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 16 Recall Announcements
