elite boiler
Pete_36
Member Posts: 19
Does anyone have experience with a elite boiler made by htproducts?
Installed a few.
I have put in a handful of the 399's in commercial applications and a couple of 220's and 299's in high end residential applications. A spec engineer in this area loves them.
I actually like them. Haven't had any problems. They are a Giannoni HX. Which I am skeptical of, but... Easy to setup with a Digital Manometer and Digital Combustion Analyzer.
Not bad. Not my favorite, but a very good high btu mod/con.0 -
Elite
I have installed a few and used to install a lot of Munchkins. They still have a few problems. I started using only fire tube boilers. I have installed a few of the Lochinvar Knight wall hung fire tube boilers and really like them. I feel the new fire tube heat exchanger is far better than the giannoni type.0 -
replies
Thanks for the replies. Anymore opinions out there?0 -
go with Triangle prestige or Lochinvar whn wall hungs
I have installed a lot of the Triangle and 8 or 10 of the whns. All good boilers. The comb. air pipe is a bit noisy on the WHN boiler more so than the Triangle but a good piece of equip.0
- 87K THE MAIN WALL
- 114 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
