Does anyone
Make a storage tank. 3' high x 1' x 1'. Need some extra storage in a tight space.
  • kcopp
    kcopp Member Posts: 4,680
    I think Vaughn...
    will make anything you want. http://www.vaughncorp.com/html/custom.html
  • Slimpickins
    Slimpickins Member Posts: 360
    edited January 2012
    What for?
    What kind of application would this be? If for DHW, perhaps a flat plate heat exchanger would be the ticket.
  • Steve_210
    Steve_210 Member Posts: 664
    I have an existing
    Indirect, and need some extra storage.
  • Slimpickins
    well
    That would be about almost a 18 gal. tank uninsulated and involve piping changes.  Why don't you crank up the temp of the existing indirect and add a mixing valve to temper the out going water?
  • billtwocase
    billtwocase Member Posts: 2,384
    Vaughn
    I used a couple of their stubby tanks years back. They were either 30-40 gallon tanks. They were great for crawl spaces.  I would check into other brands though
  • Steve_210
    Thanks all
    I have a GB 142/30, and have tried setting the HW at max. Temporally, but I still run out, just need something to take care of the initial dump. I think I found something that will fit ,
    Thanks guys. Will keep you posted.
