zone control valves
Hudson
Member Posts: 4
<span style="font-size:12pt">I have a 6 zone manifold using Telestat valves run from 24VAC Tekmar controller. They went obsolete but replaced one with a Braukmann MV100 back in 2008. Now the Honeywell Braukmann are obsolete too. </span>
<span style="font-size:12pt">Are there other replacements available with similar thread/actuation? I would appreciate any pointers. THX</span>
conversion
Telestat to PowerTrack conversion kit........have you looked at that route?0 -
Are these identical.....
I looked up the MZV series from Honeywell. It looks like a winner. THX
Do you know if the PowerTrac MZV is identical in thread type and actuation depth to the Telestats or Honeywell MV100? The product data sheet was very vague on details. I hope interchangability..
Does PowerTrak (SPARCO) have better reliability than the old Telestats? I burned through a couple of those and the MV100 has been much better.0 -
I don't know any details.It was something I came across, and figured I'd let you know about it. Good Luck0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 989 Plumbing
- 389 Solar
