European Radiators (4) White Steel Modern Design
Amy FitzGerald
Member Posts: 5
<a href="http://www.steamradiators.com/">www.steamradiators.com</a>
Visit the steam radiator website to get all the specifics on these radiators. We used them for one season in our home. They work with steam or hot water heating systems. They hook up like regular radiators. They can replace old cast iron models in your home or apartment.
Style: These sleek designs allow you to free up valuable floor space.
Quick and Easy Installation: Steam Radiators are made for both one pipe and two pipe steam systems. Single piece construction, continuous mounting, individual wrapping and tagging, and universal form fittings (which allow the radiators to be piped six ways) make Steam Radiators easy to specify and install.
Durability: The Steam Radiators' all-welded steel construction ensures a long service life. Proprietary internal construction guards against steam corrosion.
I have a total of (4) four radiators.
Two (2) of them are :
24" H x 36" W ( I HAVE 2 OF THESE) 5,225 BTU/hour current price online $805 + $40 shipping
The other (2) are :
16" H x 36" W ( I HAVE 2 OF THESE) 3,763 BTU/hour current price online $690 + $40 shipping
The total price online at <a href="http://www.steamradiators.com/">www.steamradiators.com</a> would be $1,690 + $1,460 = $3,150 !!!
Make me an offer on these radiators.
The other (2) are :
BTU output
Please correct me if I am wrong but the BTU output seems to be fairly low. For example a 36" high by 36" wide radiator seems to be only 21 Square feet EDR. Just seems like the bulk will have to be top to bottom and right to left instead of front to back. I also dont see a good place for the air vent. If the air vent has to go on the top then the BTU output is really even less then then its rating. On a steam system the narrow passageways might be prone to water hammer.0 -
Why
Why are you replacing these radiators?0
- 15.8K Strictly Steam
