LPG or OIL???
Jeff_130
Member Posts: 31
Hello,
I am still researching replacing my old boiler and have gotten some quotes but another thought occurred to me... What options are there to convert to LPG? What are the pros and cons, etc...
Oil prices seem destined to continue to rise, is LPG a viable option?
Any guidance greatly appreciated.
Happy New Year.
Jeff
Happy New Year.
Jeff
Fuel Cost Calculator
Here is a convenient Fuel Cost Calculator. I think you are probably right to assume the oil is going to continue to rise. However, LPG is going to follow right along since it is manufactured in the crude oil refining process. This is different than natural gas, which comes out of the ground as natural gas.
http://www.hearth.com/econtent/index.php/articles/fuel_cost_comparison_calculator/Dave in Quad Cities, America
http://grandviewdavenport.com0
